Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Is there way to address multiple inputs at the same time cameras, videos, etc. so that I do not have to open the "InputSelect" window again and again? Slow to setup a new session (if I do not have appropriate preset saved).
Interesting suggestion, I just don't see how you can accommodate everyone's needs or if vMix can even handle a 'multiple input' option. But I can see where it might be advantageous. My work-around of sorts is to have a somewhat 'generic' preset that loads "Lists" and "Photos" from pre-determined folders that I populate as necessary. That way, the majority of my 'needs' are loaded, I just need my cameras and replay and/or video delays to fiddle with which I tend to exclude from presets and add them during set-up.
That might work also for me, have to test. Preset what has most of the things included and then just uncheck what I do not need. Maybe the folder system works for me also.
