Showcase
Division A Summer Cup Grand Final - Hobart Jeep Zebras v Olympia FC Warriors
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
One of three games using new replay feature. Two cams only a couple of production errors, heap of experience gained. Started at 10 this morning finished 7pm. Exhausted. Division A Summer Cup Grand Final - Hobart Jeep Zebras v Olympia FC Warriors - Hobart - Tasmania - Australia Love vMix.
Nice job Ash! The only 'improvement' (if I can call it that) for your Replays is to make and use a stinger to transition in and out, although the cube zoom works well, a branded stinger would add that next level of professionalism... What cameras do you use, and how do you communicate with your camera people? Another option that I often do is set-up a static web-cam wide shot as a third camera to fall back to should the need arise for whatever reason. Keep up the good work.
Thanks IceStream Yes the stinger is on the list! Canon XA10 ground Canon Xa20 top No coms between cams at the moment on wish list, we have a briefing before game. A little research done but if anyone has some advice would appreciate it. Yes I will give the third cam a go. Had a couple of drop outs because of hdmi cable on xa10. not rugged enough. Cheers Ash IceStream wrote:Nice job Ash! The only 'improvement' (if I can call it that) for your Replays is to make and use a stinger to transition in and out, although the cube zoom works well, a branded stinger would add that next level of professionalism... What cameras do you use, and how do you communicate with your camera people? Another option that I often do is set-up a static web-cam wide shot as a third camera to fall back to should the need arise for whatever reason. Keep up the good work.
Showcase
