Instant Replay
Export and Audio Export
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi
Noticed that their is no audio on my test Export(s)
Can this be done or have I not set the audio correctly to achieve this.
Hi again.
Would anyone be able to help with this as I seem to have some success and then again some failures, not sure what I am doing incorrectly.
When I export the highlights the audio just does not get embedded in the video clip no audio at all. But I can play it in vMix with full audio as expected.
Cheers Ash
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
I had the same problem and don't have audio on all exported angles.
Does the option for "Playback Audio Source" in the Instant Replay Settings mean that all camera angles will be saved and exported with the designated audio source?
If so, then it's not working right now.
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4735 time(s) in 1624 post(s)
Instant Replay
