Thremir
#1 Posted : Thursday, February 12, 2015 5:38:19 PM(UTC)
Thremir
Greetings guys!
My brother and I produdly present to you our biggest release yet:
The vMix Midi Hardware Control Panel for Akai Mini!
This 100 buck small midi device is now capable of doing all of your standard mixing ++
Features include:
Advanced Audio Control
Active/Preview Control
Overlay Control
M/E row (MultiView)
Custom Buttons
and more to come in the next patches!
DEMONSTRATION VIDEO
Here's a quick map of the as of now programmed buttons:
http://njastad.com/akaimini.svg
WARNING: Even though it is a "set IP box" there, it is yet to be optimized for over-network commands. Please use this software on the same computer as vMix is running.
->CLICK HERE TO BUY<-
Best regards,
Håvard Njåstad
Njastad Webshop
tdurhamjr
#2 Posted : Thursday, February 12, 2015 6:14:52 PM(UTC)
tdurhamjr
Was thanked: 25 time(s) in 21 post(s)
Hey Thremir,
I ordered the Midi player and your software. We love your telestrator and I think I will be very pleased with this as well :)
Tim
mrjoe
#3 Posted : Friday, February 13, 2015 4:48:18 AM(UTC)
mrjoe
good job
mrjoe
#4 Posted : Friday, February 13, 2015 5:07:06 AM(UTC)
mrjoe
sorry but i have not understand one thing:
in your video the third row is for the overlay, and when you push the first button you switch on this input to the fist overlay....
when you push the second button you swich on the second input on the second overlay etc....
is it possible to set the overlay in different mode?
example: if i want to set the third input in the first overlay?
and another question: this key can be configured ,via config file, or fixed?
thank you
Giorgio
Thremir
#5 Posted : Friday, February 13, 2015 5:31:43 AM(UTC)
Thremir
thank you
Giorgio
We forgot to provide a screenshot for the app itself.
As you can see, you can select one input per overlay channel, and it will always be assigned to that one.
We will look into more ways to implement overlays later on in upcoming patches!
All of the buttons are pre-configured and cannot be changed (due to the light indicators not being easily re-programmable), exept for the custom row in the top where you can input any web-string you'd like, so the possibilities are many! (this is demonstrated in the video)
Thanks for your interest!
Cheers,
Håvard
mrjoe
#6 Posted : Friday, February 13, 2015 5:56:44 AM(UTC)
mrjoe
in the meantime thanks for the quick response ...
I was wondering if there was a chance to change the buttons because working in a television, we are used to having the first row of buttons at the bottom designed to preview and the second from the bottom to the program ....
I hope in the future can be implemented this possibility but I definitely will buy your software.
congratulations!
P.S. if I need a software that, via second external console, such as your or similar, can launch clips or images on a particular input?
would be useful for the production of news broadcasts or music, do not you think?
in this way I could delegate to another person the broadcast of movies.
Thremir
#7 Posted : Friday, February 13, 2015 1:36:40 PM(UTC)
Thremir
congratulations!
We had just the same in mind, and we are thinking of making a 180 degree rotated software version, so that the audio sliders are at the top, and preview/active at the very bottom, would that be an good idea?
Cheers,
Håvard
thanks 1 user thanked Thremir for this useful post.
mochaumedia on 3/3/2017(UTC)
mrjoe
#8 Posted : Friday, February 13, 2015 2:01:46 PM(UTC)
mrjoe
good idea, I think the only problem may be the usb connector that will be a little uncomfortable ...
pinkimp
#9 Posted : Thursday, February 19, 2015 5:53:30 PM(UTC)
pinkimp
Very cool!
Are there other bigger panels this could work with?
macgiver76
#10 Posted : Friday, February 20, 2015 10:41:52 AM(UTC)
macgiver76
Hello, great work!
the software work only Akay Mini?
Thank
mrjoe
#11 Posted : Friday, February 20, 2015 4:54:11 PM(UTC)
mrjoe
Hi Thremir how are you?!?
News about your software and alternative usb controller?
Thank's in advance and good job !!!
Giorgio
thanks 1 user thanked mrjoe for this useful post.
Speegs
#12 Posted : Saturday, February 21, 2015 8:12:40 PM(UTC)
Speegs
Looks fantastic :)
thanks 1 user thanked Speegs for this useful post.
tdurhamjr
#13 Posted : Tuesday, March 3, 2015 11:16:59 AM(UTC)
tdurhamjr
Here is an editable PDF file that you can fill in and print on a Transparency to lay on top of the MIDI player. After printing it just cut around outside edge. I am experimenting with some "clear glue gel" that will make it easy to affix this in the 4 corners and then remove it for a different layout. So if you need to use various layouts for different events, you can print new button layouts.
Tim
File Attachment(s):
MIDI-Overlay Layout-Blank-Fillable2.zip (383kb) downloaded 39 time(s).
thanks 2 users thanked tdurhamjr for this useful post.
Thremir on 3/5/2015(UTC), mochaumedia on 3/3/2017(UTC)
Thremir
#14 Posted : Thursday, March 5, 2015 4:17:22 AM(UTC)
Thremir
pinkimp wrote:
Very cool!
Potentially, yes, but we don't own one of these so they are on hold right now :)
macgiver76 wrote:
Hello, great work!
Thank
Yes. As of now the software is hardcoded for the Akai Mini because we don't posess any other panels, hopefully more to come in the future!
Giorgio
Hi, currently, there are no big releases of other usb controllers due to time limitation and ease of buying them here in Norway, but we'll look into some more soon!
Tim
Looking great! Awesome and cheap "hack" for the MIDI panel, +1!
Cheers,
Håvard
pinkimp
#15 Posted : Saturday, March 7, 2015 1:59:47 PM(UTC)
pinkimp
Good stuff, I got the panel just need to get the software and have and get it setup.
