I saw in the FAQ that licenses can also be transferred to a new computer. How to achieve that? Is it just to install into another computer and type the keynumber or need to send an email to vMix to request to "reset" the number of computers in the keynumber I have?
Another question is, does it still remain 2 computers only per licence? Not sure where I have read it was 3 (outside vmix site).
Thanks.
Joined: 10/13/2012(UTC) Posts: 1,157  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Simply install the software and enter your key. There are a limited number of activations of the key allowed.I suggest you try it to find the limit. Remember that the licence only allows one instance of the progam to be used at one time. That is, only one computer live at a time.
