Rank: Guest
Groups: Guests
hi martin, recently i have noticed that is some problem in time code behind vmix and FMLE. some unsync problems was detected here... we use vmix up to 4h per service at our church and sometimes, i don`t know why, we see some audio drift or some delay at video. regards, melody www.espiritosanto.ccedit: we are currently using wowza on our server.
Joined: 10/26/2011(UTC) Posts: 10  Location: Toronto, Canada Thanks: 1 times
Hi -
I'm having similar issues; trying to figure out why.
I'm using a Blackmagic Decklink 2, SDI input @ 1920x1080, 60i (source is an XDCAM Deck)
I'm using Stereo Mix for audio, as it gives me the closest results; Virtual Audio Capture is not syncing at all.
Output video settings are : NTSC 60i and 30p.
FMLE settings are for video are: VP6, 30.00, 1920x1080
By the end of a 90 minute stream, I'm about 150ms, 200ms out of syn, but perfectly fine at the beginning of the stream.
Any ideas? If you need more information, let me know.
Joined: 1/13/2010(UTC) Posts: 5,323  Location: Gold Coast, Australia Was thanked: 4727 time(s) in 1619 post(s)
Hi James,
The vMix Virtual Audio Capture is designed to stay in sync, so if you are having issues with that option, could you send a sample video clip?
Thanks,
Martin vMix
Rank: Guest
Groups: Guests
hi, i had some audio/video sync issues but now vmix is working fine here. just hit the audio delay correctly here. so, dont use another aplication simultaneously with vmix on the same pc, it may cause issues. regards, melody www.espiritosanto.cc
The only thing running on the system is vMix and 2 instances of FMLE (High speed, 500kbps and low speed 300kbps). I have had 4 instances of FMLE running, fed by vMix on my laptop before, and did not have sync issues - however I was not using a live source, just a video file. I'm trying to narrow the issue down, and I'm beginning to think it's just a frame rate issue. I will be running tests again later today, and will post the results then. The file from last night, is posted here (350MB): http://www.jamesdeane.co.../mars20120125-1800-2.flvThis is using Vmix video and Stereo Mix, as posted in my first post. the actual content starts at 32:12; we start our live stream about 30 minutes before a show starts. I will run a test this afternoon using audio delay and the vMix virtual Audio, and send that over. The file we had where the audio was early, was corrupt, so I'll have to try and recreate that effect. I appreciate the help.
Rank: Guest
Groups: Guests
if it helps you, try to use all your video inputs with the same fps to avoid issues. however, make sure if your fmle and vmix versions are the most recents. regars, melody www.espiritosanto.cc
I'm running my live test now, same show as last night from memory on the XDCAM deck. So far, so goo, as far as Sync goes, 10 minutes into the stream, using Virtual Audio Capture. http://www.snwebcastcent...s/jamesdeane/flash-test/(this will likely stop/start/die as I reset the stream and poke around) I am getting a terribly scratchy sound, which is not on the source, or on the encoder - just on the final product. Need to see what that's about
After 1 hour, I seem to lose sync by 1 frame. As well, vMix Virtual Audio creates a really scratchy sound on the end broadcast. I will post the video later this evening. Frame rates were 59.94 1080i (Decklink), settings in vMix @ NTSC 59.94i, FLME 29.97. noticed that in the program window of vMix, audio was out of sync as well as on the live stream.
I have restarted the computer, and chose Stereo Mix this time (no scrathcy sound) - will post results in about 1 hour. I don't have anymore time this evening to test this after this one last time, but will continue to do so tomorrow and next week.
Hi James,
As mentioned, if you are seeing a small delay with the vMix Virtual Audio Capture than that is expected for capture sources. This can be offset by changing the Audio Delay setting in the settings for the external output so the final video in FMLE is correct.
You will need to use the vMix Virtual Audio Capture for your tests though as the "Stereo Mix" depends entirely on the sound card and is not very reliable.
Then, I will need to see if the audio drifts in the recording or has a constant delay, if the delay is constant it is easily fixed by changing the audio delay in the vMix settings.
Martin vMix
Hi James,
As for the scratchy sound, please send through a short clip of the distortion so I can investigate further. (The flash link above does not appear to be working anymore) You can also try the following:
1. Go to Control Panel then Hardware and Sound 2. Go to Sound and then go to the Playback tab. 3. Select the item with the green tick and click Configure. 4. Under the Advanced set the Default Format to 44100 16bit 2 Channel.
This will ensure the vMix Virtual Audio Capture does not have to convert the audio, allowing an exact copy of the audio to be recorded.
Martin vMix
Thanks for all the information.
I solved the issue late last night, and I didn't get a chance to post until now.
The Decklink Audio is ONLY 48kHz; so I had to set all the audio card settings to 48kHz as well (default was 44.1). I am using the Stereo Mix as Audio source in FMLE.
I have been streaming for 90 minutes this morning with perfect sync.
Might be a good idea to allow 48kHz/44.1kHz switch for Virtual Audio.
I'm transferring the files from testing, but I will be posting the "scratchy" clip in about an hour.
I'm experiencing the same issue. I'm using a BM Deckling HD Extreme 3D, capturing audio/video in vmix with audio 48khz (no other options). I tried using Stereo Mix as well as the vmix audio capture. The sync keeps getting worse the longer it runs (in FMLE and vmix itself), it's probably the same issue as mentioned in this post.
Are you taking in JamesDeane's suggestion in the near future and offer 48/44.1 capability for your virtual audio capture? Or what is the recommended way to avoid this problem.
Thanks already for your answer
How long does the recording run for before the sync starts to be obvious? Also, does the audio start appearing earlier than the video or does it become delayed?
Thanks,
Martin vMix
Scratchy
Set all your internal playback sound card settings to 48kHz - this should help.
Once we did that, and used the vMix virtual audio, we have not had a single issue with audio drift
Hi Martin/James
Martin: Haven't measured it exactly, but I'd guess the audio delays about 200ms per hour.
I'll try James' suggestion and will post if it did the trick.
Thanks a lot for your help, much appreciated
I've been fiddling around with the machine, but I never got the drift to disappear completely. Here's some details about the machine:
Shuttle XPC SH67H7 i7 CPU 16GB Memory SSD Drive Realtek ALC 888 Sound Intel GMA 3000 BM Decklink Extreme 3D Windows 7 64 fully patched FMLE / Drivers up to date
What I've done after: - Disable Sound in Bios and use Virtual Sound Card - Make sure sound devices are set to 48khz and capturing is happening at 48khz - Chucked in an ATI graphic card - Used an Osprey 700e capture card
Audio/Video inputs I use: HD/SD-SDI / various signals
The drift varied depending on the setup, the BM capture card with disabled Audio (just virtual sound card) brought me to a drift of about 100ms/hour, other setups had a slightly higher drift.
I do use the machine to encode with FMLE without vmix and experience no drifting audio.
What is the virtual sound card you are referring to? When you have done encoding with FMLE and it was fine, what audio source have you selected?
Martin vMix
The Blackmagic Drivers (9.5) installed virtual speakers, after disabling the audio in the machine's bios that was the only listed playback device. I did try to use virtual sound card from e2esoft as well, but the drift actually increased with that.
FMLE encoding with no audio drift was done with Decklink Video Capture / Decklink Audio Capture.
Thanks for the information. There are a couple of improvements in the final release of vMix 2012 v3 that might help with the audio delay under certain conditions. Will post an update when it is released.
