Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
I welcome the new FFmpeg options in vs. 112. The 'Threads' option has fixed my audio sync problem.
Can I use this parameter somehow in vMix 14.0.0.106? There is a profile.xml file in the Streaming folder where FFmpeg.exe is located, but there is no threads parameter.
vMix is great! However v112 suddenly requires DirectX 9 to run where v106 didn't. It throws: D3DStartup.D3D_NEW_EX D3DERR_INVALIDCALL
Hopefully this won't stay an absolute necessity for furture versions.
Thanks, Martin
I agree. I often run text arabic a ticker showing the current standings after problem
Joined: 1/13/2010(UTC) Posts: 5,321  Location: Gold Coast, Australia Was thanked: 4726 time(s) in 1618 post(s)
martin909 wrote:vMix is great! However v112 suddenly requires DirectX 9 to run where v106 didn't. It throws: D3DStartup.D3D_NEW_EX D3DERR_INVALIDCALL
Thanks, Martin Martin, vMix has always required a DirectX 10 or higher graphics card. This has finally been enforced to ensure we can move forward with certain features. Time to upgrade!
Joined: 11/30/2013(UTC) Posts: 165 Location: Seoul, South Korea
Thanks: 39 times Was thanked: 19 time(s) in 14 post(s)
I had a pretty scary hour this weekend working in vMix. I went to add capture inputs for my DeckLink SDI cards and this crashed vMix when I clicked OK.  I had a project open with many inputs, and such it was easy to make the following mistake: If I add a capture input, then accidentally add the same capture input again, the entire app dies. Thought I would report this as a bug to you to be fixed. In my rush, it took me some time to figure out what caused this.
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
I don't really know if this is version 14 exclusive but;
When decoding multiple RTMP streams as inputs, all the incoming streams have the same set of audio controls, e.g. the mute, M/A/B or audio sliders works for all of my 3 RTMP inputs.
When multiviewing VirtualSets or vice versa, the qualtiy of the multiviewed input goes incredibly low, can provide screenshot to reproduce if wanted.
Keep up the good work!
Cheers, Håvard
lbgaus,
The crash info shows the error occurred in DecklinkAPI64.dll so it sounds like a Blackmagic Driver bug. There have been a few updates since 10.1.1, so download the latest drivers to see if that helps.
Håvard,
Could you provide a screenshot to demonstrate the multiview issue? RTMP streams all have to share the same audio as they use the Adobe Flash Player which does not have per stream audio controls.
admin wrote:lbgaus,
Hi Martin, Running the latest 10.3.5 version, still crashes. I figured it may be useful to just have vMix check itself before handing over the Add Input function to the Decklink driver.
Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
Hi martin, you can assign a keyboard shortcut to T -Bar?
Groups: Joined: 9/15/2013(UTC) Posts: 168  Location: Barbados Thanks: 14 times Was thanked: 14 time(s) in 13 post(s)
Hi, yes you can......go into "Settings", go to "Shortcuts", click 'Add', and in the drop down menu, select the key you want to assign, and you are good to go.....you can choose any key on the keyboard to do any function.....
