Mauro Cesar
#1 Posted : Tuesday, February 10, 2015 8:36:48 PM(UTC)
Mauro Cesar
Hi Martin,
To facilitate the identification of outputs for display 1 and display 2 the inputs should have a label below. For Example: V1, V2, B1, B2, i1, i2, P1, P2 ... because only shows the options: "output, preview, multiview, input1, input2 ..." and not the names of the entries.
Shortcuts should have an option to stay invisible in the "web interface" without losing the function. This is useful for shortcuts that work together and need not be visible.
The mirror option could be attributed to the display 1 or display 2
BUG: In a virtual input powerpoint, the virtual input of slides only change after two clicks on the forward button.
Best regards,
Mauro Cesar
cutter07
#2 Posted : Sunday, February 15, 2015 5:45:18 AM(UTC)
cutter07
To link a shortcut directly with other functions would be much better, instead of linking shortcuts with shortcuts.
Mauro Cesar
#3 Posted : Sunday, February 15, 2015 10:56:20 PM(UTC)
Mauro Cesar
thank you cutter07
The use of two shortcuts is to work with presidential teleprompter. Are two powerpoint presentations with the same number of slides, but with different content. Shortcuts advance the two presentations at the same time. A presentation is shown in the projector and the other on the teleprompter. In the teleprompter are the speaker notes.
In this case, a function for multiple inputs, would be great.
best regards
Mauro Cesar
richardgatarski
#4 Posted : Thursday, March 5, 2015 11:10:58 AM(UTC)
richardgatarski
+1
(although this has been asked for many times before, please search before asking)
Mauro Cesar
#5 Posted : Monday, April 6, 2015 5:43:07 PM(UTC)
Mauro Cesar
Thanks Martim for feature in Vmix 15. Other tip would be to apply the mirror directly on the display output (presidencial teleprompter)
Mauro Cesar
