filmmaker
#1 Posted : Tuesday, January 24, 2012 8:15:50 AM(UTC)
filmmaker
Hello everyone!
I have a question not about the software directly.
What cables do you use?
I would like to use HDMI, but what length do I get?
I tried with a 20-meter cable and it seems stable.
Give me news, thank you.
Famous Pictures
#2 Posted : Tuesday, January 24, 2012 2:18:55 PM(UTC)
Famous Pictures
I use an HDMI over Cat6 adapter. Works for up to 30 meters. Adapter was $79 US at Frys.com, the Cat6 cable was around $50 US.
http://www.atlona.com/At...R-RECEIVER-INCLUDED.html
http://www.frys.com/prod...e=sr:SEARCH:MAIN_RSLT_PG
I have it connected to an AverMedia AVerTV HD DVR card. I use three of these cards with my three HD cameras and it works perfectly. Very inexpensive. The card was $97 US.
http://www.avermedia-usa...roductDetail.aspx?Id=482
thanks 1 user thanked Famous Pictures for this useful post.
filmmaker on 1/24/2012(UTC)
filmmaker
#3 Posted : Tuesday, January 24, 2012 3:03:56 PM(UTC)
filmmaker
Thank you for your answer. I tried to directly connect two cables, each of 20 meters for a total of 40 but does not work. But I found this adapter on the Internet. What do you think? I believe we need good quality cables, to achieve the result of 60/80 meters.
http://www.lindy-usa.com...-extender-80m-32568.html
Famous Pictures
#4 Posted : Tuesday, January 24, 2012 5:53:30 PM(UTC)
Famous Pictures
Give it a try and let us know how it works out. You'll still need expensive HDMI cables though...
