Thremir
#1 Posted: : Friday, January 30, 2015 7:01:33 PM(UTC)
Thremir
Tired of checking your clock on your cellphone while under production? Want to have a handy tool in your MultiView?
The new vMix Clock set got you covered!
With both analog and digital clock (with frame counter!) you'll never be unsure again!
The watches are fully customizable and lets you select color, framerate, wether you would like ticks or smooth second arm as well as vector scaling of size.
The clocks are basic inputs which you can overlay anything!
Can be bought at:
http://shop.njastad.com/...roduct&product_id=58
Also in the picture above is the new MultiView interface we're working on for vMix, so stay with us for that!
Cheers,
Håvard Njåstad
Njastad Webshop
thanks 1 user thanked Thremir for this useful post.
Bardos on 1/30/2015(UTC)
Bardos
#2 Posted : Friday, January 30, 2015 8:19:01 PM(UTC)
Bardos
Groups: Guests
How are these clocks installed
They look great.....
Sondrey
#3 Posted : Saturday, January 31, 2015 2:13:04 AM(UTC)
Sondrey
Was thanked: 18 time(s) in 10 post(s)
They are 2 seperare DLL files, you simply drag and drop one or both into the input area of vMix, then to open the setings for each, just rightclick the input and select XAML Properties :) They end up as transperent inputs ready for use ;)
Best regards
Sondre Njåstad
Software Developer @ shop.njastad.com
Bardos
#4 Posted : Friday, February 27, 2015 2:31:03 PM(UTC)
Bardos
Groups: Guests
Thank you....I accidently ran into a clock to download, and I placed it on my desktop to see what it looked like, and it is great looking...It is a regular time clock, and not a timecode clock, but it does what I was looking for.
Bardos attached the following image(s):
vMix with clock.jpg (407kb) downloaded 65 time(s).
tdurhamjr
#5 Posted : Friday, February 27, 2015 11:55:42 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
Hi Sondre,
I installed it. A couple of suggestions.
1. Add ability to create background color on digital clock and analog clock.
2. Add ability to select time precision. i.e select options for H:M:S;xx (I do NOT want the 1/60 second numbers). So if users can decide on how precise they want their clock that would be great. Some may only want H:M while others want H:M:S and yet others want all the way down to 1/60 second clock H:M:S;xx.
I can crop the 1/60 second out but having that as an option to turn on/off would be much better. And adding background color will be very nice as well.
Tim
