Interest in MIDI Panel Audio Mixer
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Hi vMixers! When my brother and I first made our vMix audio mixer using a MIDI panel, we used a kind of expensive Ableton APC20, but now as the "new" APC Mini has been released for only half the price, I'd guess there's more interest for it now, not only is it cheaper, but the formfactor seem to be more ideal, and it no longer requires a dedicated powerbrick. Are you guys interested in us making a multi-functional software for this MIDI panel with audio sliders, lit up buttons (corresponding for when the inputs are active etc.) for mixing? Also, how would you guys map the buttons for what functions? Cheers, Håvard Njåstad Njastad Webshop
Joined: 6/29/2011(UTC) Posts: 314   Location: Florida Thanks: 6 times Was thanked: 34 time(s) in 33 post(s)
Interesting, Layout reminds me of the vMix web interface layout so I'd probably mirror that. Since you mentioned "Cheaper" have you considered the LPD8Or for that matter being able to customize for any of the Akai interfaces ?
Thremir wrote:Hi vMixers!
Cheers, Håvard Njåstad Njastad Webshop I am very much interested in it.. I shall be purchasing the MIDI panel if you give a go ahead that i will get a software to power it...
Joined: 4/25/2014(UTC) Posts: 41  Location: Norway Thanks: 2 times Was thanked: 18 time(s) in 10 post(s)
Damn2Good4U wrote:Thremir wrote:Hi vMixers!
Cheers, Håvard Njåstad Njastad Webshop I am very much interested in it.. I shall be purchasing the MIDI panel if you give a go ahead that i will get a software to power it... Hi! We allready got the software going, all we need to get is the interrest so we know we can buy this panel ourself and earn a few bucks over its cost. The more interrest the better! Best regards Sondre Njåstad Software Developer @ Shop.njastad.com
Quick update:
We bought the panel and almost done programming it, so within this week, we should probably see a release!
The layout we're thinking to use is (from top to bottom):
1. Extra buttons (Stream, External, Screenshot etc.) 2. 1 M/E for controlling multiview 3. Overlays 4. Active Output 5. Preview 6. Master Audio Channel 7. A Audio Channel 8. B Audio Channel 9. (Circle Buttons) Mute 10. (Sliders) Volume
Thoughts?
Cheers, Håvard
Wow! Great!!!
How can I use your solution? Please let me know.
Surg Lee
