Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
Hello everybody!
I'm currently trying a Rollei Mini Wifi Cam which I got from a collegue of mine. It is working fine with the App that comes with it. It streams directly to ustream as it has that feature to do so.
I non have the ip-adress of the cam as it is connected on the same network as my PC.
Is there any possibility to get the video (mp4, h264 stream) inside vMix? I already tried via "Add Input" Stream. The only possibility that doesn't bring up an error message is the "Transport Stream over TCP Pull" after I change the Port to 80.
I do not get an error message and see it as an input - however it does not show a picture.
Does anyone have a workaround or a possible solution to this problem as it would really be a nice, small and cheap camera to implement for our streaming project.
Thanks in advance for any reply.
Michael
Anyone has an idea on how to get that working? Would be great to use the direct Wifi-Stream from the action cam.
Bumping this topic. Perhaps there have been some features added since this topic was last brought up over a year ago? I, too, have a WiFi Video Camera that I'd like to add as an input to vMix.
