2 video HDMI inputs, one primary audio channel
Hi, In out church we are having 2 camcorders, connected over HDMI to vmix.
Camcorder 1 (main) is taking audio from audio console (audio console is taking from mics) Camcorder 2 has only it's mic as audio source, and is not connected to audio console.
I need to force audio from Cam1 (HDMI) to be activ when changing inputs in vMix from Cam1 => Cam2.
Normally when switching Cam1 => Cam2, the audio will be taken from Cam2 mic, and this should not happen.
Any ideas?
Thank you
@ ihtus
You should be able to "lock" the audio from Cam1 to be always 'On' by clicking the audio icon on, and clicking the double arrow icon off in the audio mixer.
Ice, thank you my Canadian friend. Will try that next time at church.
Groups: Joined: 9/15/2013(UTC) Posts: 168  Location: Barbados Thanks: 14 times Was thanked: 14 time(s) in 13 post(s)
ihtus wrote:Hi, In out church we are having 2 camcorders, connected over HDMI to vmix.
I need to force audio from Cam1 (HDMI) to be active when changing inputs in vMix from Cam1 => Cam2.
Any ideas?
Thank you Go to settings: Under "Audio". untick 'Automatically Mix Audio', and it will not switch.. Only the selected audio will be sent...
IceStream: I tried that but it didn't work.
Bardos: is it same as "double arrow" on the audio mix panel? I tried that but did not help.
What I did is this:
Unchecked all "M" (master) from all unneeded audio channels, and also unchecked double arrow. Left "M" just for audio channel from main camcorder. That seems to work for me.
