Hardware Compatibility
DekTec DTA-124 Quad ASI/SDI input card
Hi, someone can tell me if this card works with vMix? DekTec DTA-124 Quad ASI / SDI input card. Thank You
@ op music
What is your 'attraction' to this card when there are so many newer and competitively priced proven cards on the market?
At face value, I see no reason why this card would not work with vMix, but the "proof is in the pudding" as they say and I cannot unequivocally say whether it works or not. It appears to be very similar to older Viewcast Osprey 440's that are now available on ebay at a fraction of their original cost.
The questions I would ask are what Motherboard are you plugging it into and/or do you have an open PCI slot for it? What cameras are you hoping to use with it? (It lists SDI but no mention of HD or supported resolutions) If you can pick it up for real cheap, it may be worth a try, but the understanding is that it is older technology and may not do what you want it to do.
Good morning, thanks for reply, I have a computer Asus BM6835 http://www.asus.com/it/C...esktops/BM6835/overview/ operating system Windows 8 8gb ram I have cameras in SD, I would need to acquire at least 4 cameras, with a card very cheap, I tried with easy cap but I can not put more than 3, I need for my TV broadcaster born recently, was looking for a card that economic face for me. Got something to recommend? Thank You
