Hardware Compatibility
Magewell - XI400DE - 4x HD-SDI - simultaneous streaming
Hey guys,
I found on "supported hardware" that vMix works with this card. I know that it has simultaneous streaming function. But what exactly it means in reality? Idea is to connect 2 maybe 3 cameras with hdmi out (then convert signal HDMI to SDI). Distance between camera and PC about 50 meters. So i want to see live preview from those cameras in vMix in this same time, to use overlay transitions etc. Is this possible or should i search for another solutions?
Greetings, Danielos
Joined: 3/7/2012(UTC) Posts: 2,682  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ danielos
If I understand you correctly the short answer is: Yes!
vMix is a software switcher that mimics what a hardware switcher does + a whole lot more. If you can provide the input (cameras, videos, graphics, sounds) vMix can pretty much "mix" them however you want for a single program output. If you are looking to do individual streams of different inputs, then vmix might not be what you are looking for...
Ice thank You,
I want to use vMix to "mix" 3 HDMI external inputs to the one output. I was curious how Magewell - XI400DE are shown in vMix - like 4 external independent inputs?
Greetings, Danielos
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
danielos wrote:I was curious how Magewell - XI400DE are shown in vMix - like 4 external independent inputs? Yes.
Great, thank You. I will buy this card.
