I have a problem with vmix 14 with blackmagic decklink 4k, when I capture the video and then I play from the same computer, the video runs with pause, play and gives then follows, I am using the CineForm codec my video is HD 1920 x 1080i, windows server 2008 and dell dual processor.
@ cabreu13
Might need a little more information to narrow down the cause of your issue... What are the specs of your system's CPU, GPU and Hard Drive? What does the log file from the recording say? Have you tried other codecs? Do you get different results with BMD Media Express recording?
Hi ice stream
my cpu is Dell poweredge R720 windows server 2008 16 gb memory ram 4 tb disk 2 quad core xeon
Nvidia Zogi 210
my video in is 1920 x 1080 for this cineform codec
