Gopro Cineform HD codec is back ! :)
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 36 time(s) in 31 post(s)
Hi to all !!
Gopro Cineform HD free codec is back ! with the new updated version 2.5.4
Full functional with vMIx 14
Happy new year to all !!
PFBM
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
PFBM Can you explain how this works for those of us new to using GoPro?
Thanks: 5 times Was thanked: 6 time(s) in 6 post(s)
coskel22 wrote:Can you explain how this works for those of us new to using GoPro? You don't actually need to use GoPro at all. Just install the GoPro Studio program which will also install the Cineform codec. In vMix, open the Recoding Setup dialogue, select AVI and under "codec" select GoPro Cineform Codec (x64) v9.0.5. Click on the settings cog to set the Encoding Quality, Video Format and Pixel Aspect Ratio you desire. Voila, now record an AVI using the Cineform codec!
 1 user thanked ceejay7777 for this useful post.
Joined: 9/11/2013(UTC) Posts: 10  Location: Calgary Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Is it possible to edit those videos with Adobe Premier?
cbcal wrote:Is it possible to edit those videos with Adobe Premier? Yep
