atwsports
#1 Posted : Saturday, January 3, 2015 6:40:39 AM(UTC)
atwsports
Just upgraded the laptop running Vmix 11 to 14 so I can take advantage of the FFMPEG encoding.
Getting this error:
FFMPEG.Exited
[dshow @ 034B2940] real-time buffer[vMix Video] too full (85% of size: 25600000
)! frame dropped!
ffmpeg version 2.3.git Copyright (c) 2000-2014 the FFmpeg developers
built on Sep 22 2014 01:14:40 with Microsoft (R) 32-bit C/C++ Optimizing Comp
ler Version 16.00.40219.01 for 80x86
configuration: --enable-gpl --enable-version3 --enable-libx264 --toolchain=ms
c --enable-zlib --enable-libfaac --enable-nonfree
libavutil 54. 4.100 / 54. 4.100
libavcodec 56. 0.101 / 56. 0.101
libavformat 56. 1.100 / 56. 1.100
libavdevice 56. 0.100 / 56. 0.100
libavfilter 5. 0.100 / 5. 0.100
libswscale 3. 0.100 / 3. 0.100
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 0.100 / 53. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video:audio=vMix Audio':
Duration: N/A, start: 60524.103000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 1920x1080, 29.97
tbr, 10000k tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 004686A0] TCP Buffer has been set to 1048576 bytes
rtmp://was.eap2.iad.miisolutions.net/rightbrainmedia-live-8/_definst_/doPublish
7hjt5pEvsWRyNo/ryanwrestling: Input/output error
Do you know what I need to do to solve this problem?
Works fine with FMLE encoder (through VMix)
The laptop is a decent machine (ASUA 750 with an I7 4700, 8 gig of ram, NVIDIA Geforce GTX 765m, Samsung 840 SSD and I use 2 magewell hdmi usb3 doggells, one black magic thunderbolt shuttle for my capture devices with all connected to the laptop by a CalDigit Thunderbolt hub).
#2 Posted : Saturday, January 3, 2015 6:43:25 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
URLs with doPublish will need to be modified slightly to work with FFMPEG
change the bit where it says:
/_definst_/doPublish=
and change this to
?doPublish=
With everything else the same
atwsports
#3 Posted : Saturday, January 3, 2015 4:16:03 PM(UTC)
atwsports
Thanks,
Works like a charm!
ttorrez
#4 Posted : Tuesday, February 3, 2015 5:43:07 PM(UTC)
ttorrez
I'm having the same problem.
Where do I make this change?
Thank you
Ash
#5 Posted : Saturday, February 6, 2016 11:55:52 PM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
Just having the same problem with a livestream now.
I have gone back to using FMLE (at half time) but could someone clarify the answer below?
and change this to
?doPublish=
