Stream and Multicorder buttons are not displayed well
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
The buttons at the bottom of the screen are a little bit messed up since I placed a new graphics card. (Radeon HD 7750) Not a big deal, but not pretty. During starting the position of the buttons is OK. wwdv attached the following image(s):  DSC00418.JPG (605kb) downloaded 11 time(s). DSC00419.JPG (454kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
Joined: 1/13/2010(UTC) Posts: 5,208  Location: Gold Coast, Australia Was thanked: 4478 time(s) in 1561 post(s)
Looks like some files are corrupt, I would suggest reinstalling vMix.
I updated to version 106, but that doesn't help. When I reinstall my old graphic card then it's ok again. Also tried an older Catalyst driver, but still messed up buttons.
I guess its your screen resolution settings...
i will suggest you play around with higher resolution setting
I always use the native resolution, but al others resolutions have the same effect. Another monitor doesn't help either.
