mix
#1 Posted : Thursday, February 4, 2010 1:17:40 PM(UTC)
mix
I've tried the software but with all the version that I've tested there's a problem.
With the beta 9 work all the except the capured input: I've tried to attach an usb-video input card and a sony videocamera trought the usb stream but when i select it, the program gave me "Could not load Pin" and don't add the device two the input list.
With the beta 10 I've a bigger problem than the beta 9: after 2 minute that I've opened the program or when I press the "Add Input" button my system crash with a blue screen.
My system is Windows Xp
P4 1.6ghz (I know that is under the specification, but the identical problem that was on other pc with xp and a dualcore...)
Ram 1.5ghz
Mix
#2 Posted : Friday, February 5, 2010 4:24:16 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
What video card is running on the system? vMix has been tested mainly with pci-express cards.
I suspect the older system may be using AGP. AGP cards have been tested (specifically an ATI 9600/9700) but they perform quite poorly.
Also check what is displayed on the blue screen, my guess it will indicate the error is with the video card driver (if it only flashes up for a second you can disable automatic reset by right clicking My Computer -> Properties -> Advanced -> Startup and Recovery -> Settings -> Untick "Automatically Restart")
