kayonebee
#1 Posted : Thursday, December 11, 2014 12:00:42 AM(UTC)
kayonebee
I searched the forums, knowledge base, guides and Google, but unfortunately had no luck in finding an answer.
We are using vMix for sports stadium perimeter advertising and have been asked to implement a mm:ss countdown to mirror the match timing system, but I can't get the SetCountdown function to set the time via HTTP API to 40 minutes.The method is to grab start/stop/reset events generated by an official's key press on a proprietary system - another project - and use these to trigger a countdown timer appropriately.
e.g. http://127.0.0.1:8088/API/?Function=SetCountdown&Value=40:00&Input=-1 - sound about right? No luck.
It struck me that I couldn't get it working from the shortcuts panel either. Does this make it a bug or am I formatting the request incorrectly?
Version 14.0.0.102
Any help here would be very much appreciated.
kayonebee
#2 Posted : Thursday, December 18, 2014 11:27:03 AM(UTC)
kayonebee
Bumping this. Does anyone use this function, know if the formatting is correct, or having trouble with it?
I cannot get it working and think it may be broken.
Many thanks
richardgatarski
#3 Posted : Thursday, December 18, 2014 11:38:22 AM(UTC)
richardgatarski
My best guess (have not looked into your particular API details) is that your call is not fully URL encoded. Most likely the colon in "40:00" that messes things up. It should be "40%3A00"
For URL encoded strings, see
http://www.w3schools.com/tags/ref_urlencode.asp
Good luck!
kayonebee on 12/23/2014(UTC)
kayonebee
#4 Posted : Tuesday, December 23, 2014 12:11:16 PM(UTC)
kayonebee
Thanks richardgatarski for coming back to me, I see where you're coming from but unfortunately it did not work.
Tested on several other vMix installations to no avail. Still working on it, if anyone has any ideas?
tubbis_2
#5 Posted : Wednesday, December 24, 2014 2:24:16 PM(UTC)
tubbis_2
Could it be that you have to set the full time, days hours minutes seconds ie 00:00:40:00 to make it work?
thanks 1 user thanked tubbis_2 for this useful post.
kayonebee on 12/24/2014(UTC)
kayonebee
#6 Posted : Wednesday, December 24, 2014 3:02:18 PM(UTC)
kayonebee
I just tried on your suggestion tubbis_2 but also no luck. "Function completed successfully" as with other string formats, but nothing actually happened. Tried the various combinations of days/hours/mins/secs. Thinking more now that this is a bug considering it will not work as a shortcut key or through the shortcuts panel either.
Can support come back on this to confirm it is bugged and if so will be fixed in the next version?
tubbis_2
#7 Posted : Saturday, January 3, 2015 7:47:46 PM(UTC)
tubbis_2
Have you added a input with a timer?
The last bit of the API request is saying it should affect an input named "-1". Think this means the "Active" input and that's not a good idea för a timer.
Add for example the TimerClock.xaml as an input.
Then the api request for setting the time would be something like this:
http://127.0.0.1:8088/API/?Function=SetCountdown&Input=TimerClock.xaml&SelectedName=txtClock&Value=00:40:00
Starting the clock
http://127.0.0.1:8088/API/?Function=StartCountdown&Input=TimerClock.xaml&SelectedName=txtClock
Pausing the clock
http://127.0.0.1:8088/API/?Function=PauseCountdown&Input=TimerClock.xaml&SelectedName=txtClock
Stopping the clock
http://127.0.0.1:8088/API/?Function=StopCountdown&Input=TimerClock.xaml&SelectedName=txtClock
Hope this helps you...
aircooled76@gmail.com
#8 Posted : Thursday, May 17, 2018 4:10:33 AM(UTC)
Hi Guys,
I am not having any luck controlling the countdown clock. tubbis_2's suggestions do not work.
I can update and control the team scores and other fields but the timer controls are broken it seems.
Code:
http://192.168.43.5:8088/API/?Function=StartCountdown&Input=Scoreboard4.xaml&SelectedName=Clock
This is my command entered into Chrome web browser.
This command works and sets the clock text to "00"
Code:
http://192.168.43.5:8088/API/?Function=SetText&Input=Scoreboard4.xaml&SelectedName=Clock&Value=00
Any help appreciated!
#9 Posted : Thursday, May 17, 2018 4:27:34 AM(UTC)
Hi
SetText if for setting text values only. It has no effect on timers/countdowns.
Check the documentation in order to learn how to use the SetCountdown, AdjustCountdown commands.
https://www.vmix.com/hel...utFunctionReference.html
Guillaume
#10 Posted : Thursday, May 17, 2018 5:04:14 AM(UTC)
So it seems to be intermittent. I have it working with the same command on a built in vMix scoreboard Scoreboard4.xaml.
It seems to me that the command only works on the first field not on any subsequent fields.
#11 Posted : Thursday, May 17, 2018 6:44:45 AM(UTC)
No it works perfectly and reliably when you use the appropriate commands for it
stigaard
#12 Posted : Thursday, May 17, 2018 7:06:37 AM(UTC)
stigaard
Denmark
@kayonebee and @aircooled76@gmail.com
As I see, you need to remember the SelectedName parameter in the url. This enables the command to choose exactly which field in the title is instructed to e.g. start, stop, adjust or set the countdown.
Good luck :-)
desmar
#13 Posted : Thursday, May 17, 2018 10:13:51 AM(UTC)
desmar
Canada
To Set countdown to 40:00 and display 40:00 on title.
The following commands must be sent.
Using title Title2Blue.xaml
Changed the Live Field to a countdown.
(As Live is the 3rd Field Index value is 2)
(Index always starts at 0, 1, 2 etc)
1) Set Countdown Field of Live to a countdown timer to 40:00.
(This will NOT set text to display 40:00 on title)
http://127.0.0.1:8088/API/?Function=SetCountdown&&SelectedIndex=2&Value=40%3A00&Input=1
2) Set text of Live to display same as countdown timer to 40:00.
(This will set text to display 40:00 on title)
http://127.0.0.1:8088/API/?Function=SetText&SelectedIndex=2&Value=40%3A00&Input=1
#14 Posted : Monday, September 10, 2018 12:42:28 PM(UTC)
Code:
http://192.168.X.XXX:8088/API/?Function=StartCountdown&SelectedIndex=4&Input=SB
Works... thanks
mjc
#15 Posted : Thursday, April 29, 2021 8:10:18 AM(UTC)
mjc
Function=SetCountdown&Value=00:05:00&Input=135
This worked for me but it did not show the new value until after I started the countdown.
#16 Posted : Thursday, April 29, 2021 8:20:35 AM(UTC)
About every 3 years this post gets some attention ;-)
