homeless
#1 Posted : Friday, December 12, 2014 2:12:49 AM(UTC)
homeless
Groups: Guests
I try to use multivew. Main input is background video (it is short video, i loop it in vmix). In this input i edit multivew option to set 2 windows over background. In this windows i send 1 video-file and some capture. In video-file input i set Autoplay when transition and automix and autorestart. But when i get transition to this multiview - background video started and looped normaly, but video-file in multiview not started (automatic audiomix worked) !!!
#2 Posted : Saturday, December 13, 2014 1:08:00 AM(UTC)
@ homeless
I tested your scenario with 4 videos (3 overlays in MultiView of video BG) and it worked for me (all-be-it not smoothly but that is a separate issue).
Are you sure all your settings are correct?
How are you transitioning to that "Main" input?
Do the individual videos play properly on their own?
What are the specs of your system and what video format(s) are you using?
(Mine are all AVI)
homeless
#3 Posted : Saturday, December 13, 2014 1:21:58 AM(UTC)
homeless
Groups: Guests
Main input transition - simple "cut"
Main input settings - Automatically mix audio=on, Automatically Play/Restart/Pause with Transition=on
Multivew video inputs - Automatically mix audio=on, Automatically Play/Restart/Pause with Transition=on
And when i "cut" main video to program output - i see that in multivew video inputs Audio tabs set to active, but video not started.
May be i use old version - 11.0.
