How can I make a small play window in top left hand corner
I need to be able to make a play window in top left hand corner to show my output to need some help
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
VMix defaults to Preview in the Top Left and Output in the "Top Right". Is there a reason you need an additional windows showing the ouput window?
Joined: 6/29/2011(UTC) Posts: 315   Location: Florida Thanks: 6 times Was thanked: 34 time(s) in 33 post(s)
If your trying to do a PIP (Picture In Picture) but also keep a full size version to switch to then make a virtual copy of input you wish to place in corner. Then open properties panel of copy and scale down and position the window in desired location.
