valkanela
#1 Posted : Saturday, November 15, 2014 9:25:49 AM(UTC)
valkanela
Was thanked: 6 time(s) in 2 post(s)
So, how about a two simple external apps, one will have 48 slots for fast visuals change (swf, avi, mp4, name it...), and the other one will provide text scrollers, edited by users and SMS text pusher? Will this be interesting?
Your opinion is important. Apps are already finished, connection with V-Mix depends on interest. Regards...
P.S. I kindly asked for your opinion and comments. Thanks for thumbs up, but this will not move the things further. Will this be useful, would you like to post SMS messages into your stream, and so on...?
thanks 5 users thanked valkanela for this useful post.
num127 on 11/16/2014(UTC), madness on 11/19/2014(UTC), Ash on 11/23/2014(UTC), OpenROADer on 11/25/2014(UTC), jeffrex on 1/10/2015(UTC)
valkanela
#2 Posted : Tuesday, November 25, 2014 4:41:50 PM(UTC)
valkanela
No responds, no plugins. Please, comment.
Damn2Good4U
#3 Posted : Tuesday, November 25, 2014 6:34:15 PM(UTC)
Damn2Good4U
+1 for the SMS pusher and if possible to have Whatsapp or BBM integrated as well..
How about looking at Voting system for like Music countdown voting etc?
TVIason
#4 Posted : Tuesday, November 25, 2014 6:52:45 PM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
This is a great idea. Sorry for the lack of interest before. I really think it's wonderfull that you made these kind of apps! Are they in beta or something?
valkanela
#5 Posted : Wednesday, November 26, 2014 6:14:18 AM(UTC)
valkanela
Well, we need some reactions. Just comment and give your ideas.
madness
#6 Posted : Wednesday, November 26, 2014 10:30:10 AM(UTC)
madness
Sorry, I thought this post was directed to Martin, otherwise I would have chimed in for my support of such plugins. I didn't look to see what forum it was in. I suspect many others did the same, and assumed this was a feature request. Notice however, that I did thank you for the post previously.
I would love to have visualization support. Built in/native, or plugin!
I've been looking at using Visikord in desktop capture mode, but that will obviously add some latency for the dancers.
wtmuradiotv
#7 Posted : Thursday, August 20, 2015 9:44:35 PM(UTC)
wtmuradiotv
I think it would be a great idea the mix features of vmix are boring they really need to up grade the features for the price of the program ....Special mixing effects etc would be good
ShadowGauge
#8 Posted : Sunday, November 22, 2015 2:38:33 AM(UTC)
ShadowGauge
PLEASE GOD!!! I have been trying to code on internally with xaml code but the effects are so primative.. course I have no idea how to code so that I got anything to trigger at all is quite a feat,but simple screen blinking is not gonna cut it in my world... So yes plz, and if anyone has figured out how to get milk drop to work inside of vmix lemme know.. I dont know how to convert vlm code to..anything really..blah blah blah just give us the plugin.. J/k.. buts seriously.. yes
valkanela
#9 Posted : Saturday, December 12, 2015 7:01:04 PM(UTC)
valkanela
If you want to display Milkdrop in vMix, use 'Syphon for Windows', Spout:
http://spout.zeal.co/for...lugin-with-spout-output/
valkanela
#10 Posted : Saturday, December 10, 2016 8:53:04 AM(UTC)
valkanela
There's still a chance for this. Visual plugin will be ideal for fast triggering. Don't be confused with upper comments, there's no Milkdrop in this case. Like I mentioned, it will support swf, animated PNG, transparent videos and so on.
The other plugin will give you a possibility for some social activities, please comment what is important for you. Thanks...
zenvideo
#11 Posted : Saturday, December 10, 2016 1:20:28 PM(UTC)
zenvideo
Dose this app create output via NDI? If not, it would be a good addition in order to connect not only with vMix but many other systems as well.
valkanela
#12 Posted : Monday, December 12, 2016 4:55:23 PM(UTC)
valkanela
There are too many 'not's in your sentence, I'm slightly confused will NDI be ok or not? ;-)
zenvideo
#13 Posted : Monday, December 12, 2016 6:50:52 PM(UTC)
zenvideo
OK, I'll break it down:-
1) I think support for NDI would be good.
2) I do not know if you support NDI, or are thinking of supporting it.
3) If you do not already support NDI, I think it would be good to add support for outputing via NDI.
4) If support for NDI is added, it will not only allow ingest into vMix, but also into other video software.
Digitalson
#14 Posted : Tuesday, January 17, 2017 3:32:15 AM(UTC)
Digitalson
Groups:
Definitely I am one for putting dve effects into vmix,,,I mean cmon grass valley boards had some simple effects 30 years ago ,and we are digital now!!!!
Ittaidv
#15 Posted : Wednesday, March 1, 2017 8:39:38 AM(UTC)
Ittaidv
There is now a software to convert spout to ndi :http://spout.zeal.co/forums/topic/spout-to-ndi-syphon-to-ndi/
This means winamp milkdrop can be used as an input, and many vj programs.
It opens some options: using resolume as a graphics server, generating gfx in realtime, which reacts to the music.
The plugin from the screenshot is called tellyvisuals, which is a plugin for virtualdj. Virtualdj has a spout output, which could be converted to NDI. I think this is a bit complicated for a workflow, although technically it should work :)
There are multiple other plugins for virtualdj though: https://www.virtualdj.co...ex.html?category=effects
Some of them might be useful to be taken into vmix.
Still it's not the same as using gfx built into a video mixer: you can't use the effects as transitions for example.
Teye
#16 Posted : Wednesday, June 14, 2017 6:25:19 PM(UTC)
Teye
I'd like to see live realtime FX per channel.....they would have to be the less demanding types of effects or something through an alpha channel arrangement....that would allow for a whole lot of creativity..it's to bad that Vmix doesn't have a plugin architecture for tight integration and optimal performance....
