Ittaidv
#1 Posted : Monday, November 24, 2014 5:26:01 PM(UTC)
Ittaidv
Last night we had problems to auto restart our overlay video. We always had to load it seperatly and press the restart manually. It's a 14 second clip that uses a blue key. It's strange because our svo's were working correctly, while being the same codec, also keyed, but a little shorter. Any ideas what might cause this?
#2 Posted : Tuesday, November 25, 2014 2:00:09 AM(UTC)
Was thanked: 4640 time(s) in 1603 post(s)
What type of video is it and what version of vMix are you running?
If you open up vMix an add the video by itself and set it to Loop does it restart correctly?
Ittaidv
#3 Posted : Tuesday, November 25, 2014 11:47:10 AM(UTC)
Ittaidv
This is the file: https://jumpshare.com/b/MWYsCyEGrghtwxgBHC8d
We keyed it using the built in keyer. Setting it to loop didn't change anything.
We use the latest version of Vmix.
#4 Posted : Tuesday, November 25, 2014 1:10:33 PM(UTC)
Looks like the .m2t file does not have a well defined duration.
I would recommend converting to .mpg if possible, otherwise you can try renaming it to .mov
so it uses a different playback engine in vMix.
Ittaidv on 11/25/2014(UTC)
Ittaidv
#5 Posted : Tuesday, November 25, 2014 3:00:21 PM(UTC)
Ittaidv
Thanks a lot, will try this later, it must have been the file then.
