mustangnaz
#1 Posted : 10 years ago
mustangnaz
Has anyone had any luck with the Osprey 100 4 channel capture cards? Adobe FMLE sees all 4 inputs, you can use only one at a time.
Vmix will see channel 1 or s video but not a the same time. And will see both cards without a problem, just not seeing the extra inputs.
I have two of the osprey 100 cards for our church. Would really like to find a way to get these to work. I think they would work if on the input list they had composite 1 composite 2 composite 3 / svideo.
6 channels on sd is what im needing.
Currently we film in SD 640 x 480.
Ideally I would love to use vmix as our mixer, but we need just need some other ideas on what might work with sd.
I do know the Haupauge USB Live 2 Works great on Vmix.
Thank you,
Paul Wood
Charssay
#2 Posted : 10 years ago
Charssay
Hello Paul,
The Osprey 100 is not a 4 channel but a one channel with switchable input. It's then normal taht you can use one channel at that time. If you want to get six input, you better change the card and you more than one card. The Osprey 440 can be a answer. But there is more problem with this card, facing by some user.
Don't even try the Hauppauge if you want great quality capture and if i do not mistake, this card is recognize in Vmix but give an error when you try to use the input.
Could we know how your hardware is ?
You can try this Magewell Card XI006AE-PRO
http://www.magewell.com/...ae_features.html?lang=en
You will get six SD input with it, and will recommand you to have a good CPU for a good stabilty
C.
mustangnaz wrote:
Thank you,
Paul Wood
mustangnaz
#3 Posted : 10 years ago
mustangnaz
Thank you for your reply.
My set up is pretty nice.
Board: BIOSTAR Group TZ77B 5.0
BIOS: American Megatrends Inc. 4.6.5 04/19/2012
Windows 7 Professional (x64) Service Pack 1 (build 7601)
3.30 gigahertz Intel Core i5-3550
No memory cache
64-bit ready
Multi-core (4 total)
16 gigs of ram-15.97 available.
1tb hard drive.
Nvidia Gt8500 512mb graphic card
In Rack mount case =)
The problem is I don't have enough PCI Slots, I would like to find a PCI to USB 3.0 that could be external.
I have 2 regular pci
2 pcie
2 pci x 16 (one used for nvidia graphic card)
On my set up the ospreys/haupauge usb2 live is stable.
I have left the haupauge recording for about 10 hours, no errors. And have streamed about 3 hours with it.
Here is the link. http://www.hauppauge.com...ducts/data_usblive2.html < this one we normally use with just a laptop for portable shoots, but on the tests it was used with vmix to record/stream
Thank you,
Paul Wood
Mustang Church of the Nazarene
ngtech
#4 Posted : 10 years ago
ngtech
try WInnov 4400VO 4 Channel pci Video Capture card, this works great for me I record SD 720 x 480,I am happy with the video quality, you can change it to sd 640 x 480
ngtech attached the following image(s):
mustangnaz
#5 Posted : 10 years ago
mustangnaz
So I came across the osprey 440 got to of the cards installed with out any issues on my windows 7 64 bit system.
Nice and smooth, no lines.
I do have an Extron Scan Converter taking the 1080 signal back down to SD for the DVD Recordings/the SD TV Modulator for our inhouse cable system.
I have an HD Qmod modulator that Im going to hook up next week.
mustangnaz attached the following image(s):
mk2007
#6 Posted : 10 years ago
mk2007
can you tell us Winnov 4400 vo capture card work also as 16:9 in window 8.1 ?
ngtech
#7 Posted : 10 years ago
ngtech
it should work, I am running win7 64bit, I use 3 cameras, settings on camera as 16:9, widescreen aspect ratio on Vmix Settings
mk2007
#8 Posted : 10 years ago
mk2007
ngtech : thanks for your reply
window 8.1 ?
you have WInnov 4400VO window 8.1 driver or win7 driver work in window 8.1
ngtech
#9 Posted : 10 years ago
ngtech
window 8.1 ?
the links below will answer your question
http://www.winnov.com/pr...m/videum-4400-vo-xpress/
http://www.winnov.com/pr...river-3-7-release-notes/
mk2007
#10 Posted : 10 years ago
mk2007
ngtech wrote:
window 8.1 ?
i find windows 8.1 driver
https://www.swingcatalyst.com/drivers
http://cloudfront.swingc...s/WnvAvs_3_8_Release.exe
please anyone who have Winnov Videum 4400 VO 4 card try this driver in windows 8 & windows 8.1
ngtech pls try
mk2007
#11 Posted : 10 years ago
mk2007
when i try WInnov 4400VO 4 Channel pci Video Capture card with vmix 11
this error show
AddNewInput
Capture Device Is Not Supported, Device Reported the following: Capture
32595559-0000-0010-8000-00aa00389b71
what should i do
can you pls share your setting with us
Similar Topics
OSPREY 100 Windows 7 64 Bits (General Discussion)
by meachou 10 years ago
