tgdzapa1
#1 Posted : Tuesday, November 11, 2014 10:40:38 AM(UTC)
tgdzapa1
Hi
I know the very very expensive EVS System. Also the Newtek product:
http://www.newtek.com/pr...s/3play-425-home-sm.html
and the product from : http://lgztech.com/lgz1-hd-sd
All this hardware solutions costs around 15'000 - 20'000 USD. Knows everyone
a cheaper hardware system?
Yes I know vmix has a integrated replay (SloMo) but my PC with Intel Core i7-4770K (3500) Quad Core
is not strong enough for works with 4 cam inputs and 3 replays. CPU is on 100%.
Should I upgrade my processor like for exemple Intel Xeon E5-2697V3: 14-Core with 4 cam inputs and 3 replays?
Thanks for replies.
Patrick
r@wisla
#2 Posted : Tuesday, November 11, 2014 4:25:13 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Thanks for replies.
Patrick
It's not only about CPU, but also graphic card, disk drives and capture card.
I just tested an i7-4790K PC with one SSD, not that new Radeon graphic card with 2 cameras 720p@50fps and 2 instant replay. The CPU usage wasn't bigger then 20% and the PC were recording and streaming.
I guess You should also wait for new vMix Instant Replay solution based on Multicorder http://forums.vmix.com.a....aspx?g=posts&t=2454
tgdzapa1
#3 Posted : Wednesday, November 12, 2014 5:26:52 AM(UTC)
tgdzapa1
cool !
The set-up with a second PC needs a video hub like this:
https://www.blackmagicde...s/smartvideohub/workflow
to route 4 cams to the replay, right?
Then we have a the following process:
1. Four incoming cam inputs to the hub
2. Route 4 cams stream to pc1 for mixing and route the same 4 (or fewer) cam streams to pc2 for replays (does a second operator)
3. pc2 output of 2 (or more) replay streams to pc 1.
4. So we have in pc1 4 cammonitors and 2 replaymonitors to mix
On the end we have to have on pc1 6 (or more) inputs (hdmi or SDI).
Right?
Thanks for replies.
Greetings to Poland
Patrick
r@wisla
#4 Posted : Wednesday, November 12, 2014 7:53:49 AM(UTC)
r@wisla
Sure, it can be done like this. Quite elegant workflow. The only thing I don't understand is why You want to output 2 signals from replay machine (PC2) to PC1. One is not enough?
I see two different options, they have pros and cons.
OPTION 1 is with 2 PC-s and no video hub. Blackmagic Quad cards have a pass thru video outputs, so you can input 4 cameras to PC1 and output them to PC2.
OPTION 2 is one PC only with two operators: one is working with keyboard and mouse on replays and second does mixing (switching, lower 3rds etc...) with some external controller (MIDI device, laptop, tablet).
