5 Pages«<2345>
PFBM
#61 Posted : Tuesday, November 11, 2014 7:59:04 AM(UTC)
PFBM
admin wrote:
EDIT: Revised to make things easier to understand.
Magewell Deinterlacing
From Add Input -> Camera
1. When using an interlaced frame rate, such as 59.94i, vMix will disable the interlacing on Magewell cards.
2. When using a progressive frame rate, vMix will leave the Magewell card with its default settings.
Note: If you have selected interlaced for the camera in the past, it may still have its deinterlacing disabled,
to enable it again, go into Input Settings, Advanced, select the Magewell device and adjust the properties there.
It should be stressed that using the Magewell deinterlacing is not recommended, and there is no advantage
to doing so besides being able to use the sharpen effect in Input Settings.
Streaming Crash
Unfortunately I will need detailed information to diagnose this issue, including
error message and the hardware setup on the system. Note that FFMPEG streaming like FMLE is completely isolated
from vMix, any crash in FFMPEG will take down the stream only and it can be started up again straight away by clicking the stream button.
AVI Recovery
It may be possible to recover the AVI file depending on the codec used.
I have an experimental utility I am working on, email info@vmix.com.au to try it out.
It is recommended that the "New file every" feature is used with AVI recordings, it is seamless in vMix 14.
deinterlaced problem solved. was driver problem.
The latest XI400DE-HDMI driver can be download from the follow link:
http://61.155.106.24/dow...I400DE_HDMI.20141110.zip
and latest firmware :
http://www.magewell.com/...H_REV_A_ID_0_VER_1_2.rar
did all that and solved the problem
i still use Cineform HD codec ( go pro ) version 2.01 is still free.
use it on avi recording.
Best regards,
PFBM
h2video.nl
#62 Posted : Thursday, November 13, 2014 8:46:29 AM(UTC)
h2video.nl
hi Martin,
just updated to vmix 14 101.
i have had some problems lately with bm drivers. there was a major update and this also updates the chip on the shuttle and the cards, be aware.
but besides that i notice something strange. I keep a close eye on the incomming framerates, because i did a lot of testing after the bm updates. when i capture a camera i get a nice clean 40 ms reported on the capture. but as soon as i turn on external ( in this case a bm mini monitor) the incoming framerates go everywhere.
is this something to worry about. what could be the problem. when i turn off exyernal everything is neat and tight.
is there some interference ?
stefan
h2video.nl
#63 Posted : Thursday, November 13, 2014 8:47:47 AM(UTC)
h2video.nl
hi martin,
in addition: i don't get my audio in sinc using wmv streaming. what could be wrong.
stefan
wwdv
#64 Posted : Thursday, November 13, 2014 2:41:29 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
The negative audio delay doesn't work:
I can not give my audio inputs a negative audio delay, I can set it, but the delay is still 0.
My audio has more delay in vMix than my video. (the performance statistics shows: video 40ms delay, audio 80ms delay)
How is it possible that audio has a bigger latency than video?
ovinas
#65 Posted : Thursday, November 13, 2014 3:16:47 PM(UTC)
ovinas
Changes and Features
* Stereo audio inputs can be split into two independently controllable mono sources...
That's a nice feature but could you please bring back the "mix to mono" option as an addition?
ovinas
#66 Posted : Thursday, November 13, 2014 3:28:48 PM(UTC)
ovinas
Try to delay the video: Input settings (Cam) --> Advanced.
wwdv
#67 Posted : Thursday, November 13, 2014 4:32:00 PM(UTC)
wwdv
I want to minimize my video delays because I am presenting it also on a beamer.
I already got some audio sync issues.
I am just wondering why the audio has such a big delay.
ovinas
#68 Posted : Thursday, November 13, 2014 4:41:40 PM(UTC)
ovinas
Negative audio delay "is" video delay or you have a time machine ;-)
What's your audio input device?
Is it visible on the projector? The projector will add some delay so it could match perfectly with your audio.
wwdv
#69 Posted : Thursday, November 13, 2014 4:55:11 PM(UTC)
wwdv
I thought that a negative audio delay will delay all video sources at the same time.
But an extra video delay is undesirable anyway, the beamer is showing a camera image from a live narrator.
My audio source is a onboard audio device (Realtek ALC888).
A VU meter tool that is monitoring the line in shows no delay, so why does vMix have so much audio latency?
BTW. FMLE is generating an extra audio delay of 100ms, if FMLE was generating a video delay then my problem was solved. :)
It would be very nice if vMix had a video delay only for streaming (external output), that would not affect the fullscreen output.
ovinas
#70 Posted : Thursday, November 13, 2014 6:02:42 PM(UTC)
ovinas
Could be the ALC888. You can measure the latency/delay of your audio device with this tool: http://www.oblique-audio.com/free/rtlutility
It shows ~40ms for my onboard Realtek HD, ~50ms for a Behringer UCA202 USB and ~80ms for a Focusrite Saffire 6 USB (all with 480 samples buffer). Because this measurement is for output plus input (round trip), using only one of them will cut it in half. That's ~20ms on the input of the Realtek HD and matches my Decklink Mini Recorder.
In all my setups and events with different configurations and devices I never had to delay the video, always the audio.
vMix only shows the delay for your video capture device. Normally you will have additional delay by the cam on that input. But that's all theory. Nothing better than the good old clap test.....
#71 Posted : Thursday, November 13, 2014 8:54:04 PM(UTC)
Regarding audio delay, there is a processing delay in vMix of approximately one frame.
This is why the stats can show 40ms for the video and 80ms for the audio, at the fullscreen output these will be in sync.
wwdv
#72 Posted : Friday, November 14, 2014 4:43:37 AM(UTC)
wwdv
When recording things are different, then I have to use an audio delay of 100ms, so it seems that FMLE is the problem.
Is there a possibility to delay only the video that is streamed and not the fullscreen output that is showed on a beamer?
EDIT: problem solved: Chrome is the problem, in FF en IE the sync is OK.
Tried it on a few other computers with the same results.
wwdv
#73 Posted : Sunday, November 16, 2014 8:01:27 AM(UTC)
wwdv
Every time after starting vMix I have to press the configuration button otherwise I've got the error: recording has not been configurated (but all settings are OK).
I've send the error report.
The recording fader will only show up after pressing the configuration button.
#74 Posted : Sunday, November 16, 2014 4:23:14 PM(UTC)
This is by design so you can verify recording settings before starting.
You can change this behaviour in settings under the recording tab.
This is how recording has worked in all versions.
wwdv
#75 Posted : Tuesday, November 18, 2014 7:27:13 AM(UTC)
wwdv
Thanks, I never used recording before.
h2video.nl
#76 Posted : Sunday, November 23, 2014 4:24:01 PM(UTC)
h2video.nl
vmix version 14.0.102 ? but what has changed since 101?
hi martin just noticed the current vmix version is updated to 102. but i can not find any info about changes.
would it be a good idea to have a non comment release thread on the forum where you can post the change log for updates.
this way it is simple to have a one click overview of changes and it is more easy to deside if and when to update.
just a thought. now you have to look all through this threatvwoth comments to find the changes. this could still be the comment threat and in addition have the non comment overview of changes.
stefan
wwdv
#77 Posted : Tuesday, December 9, 2014 8:21:10 AM(UTC)
wwdv
The CPU usage in V102 is much higher than in V101.
When I start vMix 14.0.0.102 without presets loaded, the CPU usage is 24% (V101 2%)
#78 Posted : Tuesday, December 9, 2014 9:24:56 AM(UTC)
wwdv,
Could you provide a screenshot?
There is only a small fix in the shortcut UI in 102 which has no effect on CPU.
It sounds like maybe a setting has changed or some hardware is impacting the CPU.
wwdv
#79 Posted : Tuesday, December 9, 2014 9:49:59 AM(UTC)
wwdv
I've found the problem:
I've disabled all the visual effects (except visual styles) to speed up my system.
With 'Desktop composition' enabled the CPU usage is normal again.
Why does vMix need this?
I hope this can be fixed, because when I access my stream computer remotely, vMix is using high CPU again.
(The Radmin mirror driver seems to disable 'Desktop composition')
richardgatarski
#80 Posted : Saturday, January 17, 2015 10:26:26 AM(UTC)
richardgatarski
Martin,
Thanks for all the updates!
Running 14.112 the New Graphics Adapter selection box in vMix Settings only shows Intel HD graphics family on my Asus UX302 laptop. Does not matter if I start vMix using "run with" Integrated of Nvidia. (Win8.1)
Special thanks regarding the ffmpeg streamer improvments, in partucular organge indicator. We have had som disconnect errors that I have not had the time to report, guess the auto reconnect will have fixed that.
Would be really useful if the Help/documentation covered the new ffmpeg settings.
cheers,
/richard
5 Pages«<2345>
