PastorJorgeL
#1 Posted : Thursday, October 30, 2014 4:05:31 PM(UTC)
PastorJorgeL
Hi I am new to this, just getting my feet in the water here. I downloaded Desktop Capture on a MAC, installed it but it just wont start ... I did it on a PC no problems at all. Thanks
hogwam
#2 Posted : Friday, October 31, 2014 5:37:43 AM(UTC)
hogwam
Download the DesktopCapture ZIP from http://www.vmixhd.com/download.aspx
When you open the ZIP, the file will decompress in to the folder you saved the ZIP - usually your Downloads folder.
You're looking for a file called vMixDesktopCapture.app
Drag vMixDesktopCapture.app to your Applications folder (you'll find it on the left-pane of your Finder window).
Go in to the Applications folder and double-click vMixDesktopCapture.app - the first time you run it you will get a security message about opening new programs - just click 'Open' on that and you won't be warned again.
As long as your Mac is connected to the same network as your vMix PC, it will show in desktop capture on the vMix console.
NOTE: if the local firewall is blocking all incoming connections, you'll need to allow vMixDesktopCapture.app through - see instructions here;
http://support.apple.com/kb/PH11309
PastorJorgeL
#3 Posted : Sunday, November 2, 2014 3:10:59 PM(UTC)
PastorJorgeL
yes,this is the steps i took. However the program wont start. tried checking the FW it was turned off. I turned on and allowed the program to accept remote connections, but just wont start.
Tried, deleting it and un zipping again ... same result
#4 Posted : Sunday, November 2, 2014 11:02:30 PM(UTC)
Make sure you have downloaded the OSX version of the program and that you have OSX Mountain Lion or higher installed.
tnorrell
#5 Posted : Sunday, December 7, 2014 2:40:32 AM(UTC)
tnorrell
Was thanked: 13 time(s) in 10 post(s)
System Preferences -> Security & Privacy -> Firewall -> Firewall Options
You can allow the app to accept incoming connections there
(be sure to unlock the panel before you click firewall options)
