Joined: 10/19/2014(UTC) Posts: 3 Location: Reno Nevada
I use multiple Screen Captures and it would be nice to have the Input Screens and Other Screens open in the same place (after having been moved to a safe part of the screen) each time the Screen is called so that they do not open over the Screen Capture.
Here are some screen captures of the problem I am having with Windows opening on the wrong part of the screen. Maybe Martin can provide me with a work around. If not it would be a nice feature to add to a future version. My screen no Input Select window open.  With an Input Select window open.  Where I would like an Input Select window to open.  Thanks Doug
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Dude, just plug another monitor into your computer. I think you want too many things on one screen, looks kinda messy.
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
If you're worried about the window being on top of the capture window, some windows support being captured in "hidden" mode which means they will capture correctly even with windows over the top.
You can tick the Capture Windows check box in the Desktop Capture settings to use this option.
