Hi All, Just wondering if anyone has successfully used an Epiphan VGA2Ethernet device with VMix? (This converts VGA or DVI or HDMI to a stream over ethernet, and is apparently compatible with any Directshow compatible device) This is the device I'm referring to: http://www.epiphan.com/p...e-grabbers/vga2ethernet/ The application is presentation capture at conferences. Thanks, greatly appreciate any experience shared.
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
I've used a similar device - http://visionaudiovisual.../techconnect/tc2-matrix/simply take a HDMI output from the graphics card and transmit over the network to a large screen at the other side of the park. These run at 50Mbps - You need plenty of network capacity if you're thinking of running several n.b. as with any of these type of devices, both TX & RX need to be in the same broadcast domain/subnet
 1 user thanked hogwam for this useful post.
Thanks for that Hogwam - looks like an excellent and cost effective device. I take it you've had a good experience - stable TX and good picture quality?
Two features I do need though are VGA capture as well as HDMI, but also the ability to "loop through" any signal, so I can screen-grab an output from a laptop, but it can then be passed on to any external display device such as a projector.
