medialivecasino
#1 Posted : Thursday, October 9, 2014 6:03:13 AM(UTC)
medialivecasino
we are looking for the right graphic card to fit inside one hp server dl320 gen8
tried with gt640 but gpu go near to 90% ...
we are thinking to try the the Quadro K2200 that should fit in the single slot ...
are the Quadro cards supported by vMix ?
Thank you
vojam2001
#2 Posted : Thursday, October 9, 2014 5:43:30 PM(UTC)
vojam2001
I'm not sure that vMix supports Quadro cards. Performance of the two cards is pretty similar and Your problem is the computer for vMix, in terms of dimensions.
http://www.videocardbenchmark.net/compare.php?cmp[]=1432&cmp[]=1543
Sorry for the Google translation.
Regards.
medialivecasino
#3 Posted : Friday, October 10, 2014 5:53:52 AM(UTC)
medialivecasino
sorry but your link compare the gt640 with the quadro 2000
this is the comparison with the new quadro k2200
http://www.videocardbenchmark.net/compare.php?cmp[]=1432&cmp[]=2947
if is just know if is supported :)
