zenon
#1 Posted : Wednesday, October 8, 2014 5:18:12 AM(UTC)
zenon
HI,
On the trial version I have downloaded, I'm preparing for some of radio customers some API . Over these API we will be able to link our Broadcast automation to the Vmix used over Http shortcuts in sync with our product.
I saw that with AddInput I can add an input with a video file, this is ok, but when I try to use Vmix as scheduled player, I would like to use 2 or 3 inputs (all the time the same to be able to use some preset trigger) and I just need to change the video file on the input over http..
Actually I see only the http AddInput able to assigna filename to an input. After video has played I need to remove the input and create a new one, but in this case I cannot put the trigger in a preset.
Is there a Way I overseen to replace the video file in an existing Input ? That would be nice for me.
Thx
Dominique
