Upgraded this week to 14 from12. 12 was working well both local and on streaming good audio on both mp4 local and on the live stream. No changes to hardware but now our music is clipping rather badly although speech is fine. Lowering the input audio (we use a audio out from the audio mixer for all audio input to vmix) simply lowers the volume but still seem to have overdriven clipping on music performed! Here is a short sample https://vimeo.com/108053051 Any ideas. I do notice much more CPU load with 14 over 12! In fact now near 90% - 95% when recording and streaming. Was only about 75% on 12. Streaming out at same settings as 12. All recordings are done SDI. Audio into mic input on computer using internal audio board. Was fine now not so good? Any ideas!
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Check over all the settings in vMix 14. If the CPU usage is higher than the resolution settings might have changed. Check the output size in vMix Settings and in External Output tab. Reducing the external output size will reduce the CPU when streaming.
Martin vMix
