Ph0en1x
#1 Posted : Friday, October 3, 2014 5:07:07 AM(UTC)
Ph0en1x
Is it possible to use two outputs simultaneously on the Intensity Shuffle (i.e. splitting the signal)?
So:
Camera
HDMI cable
Intensity Shuffle ===Thunderbolt cable===> Macbook
Component cable
Windows PC
richardgatarski
#2 Posted : Friday, October 3, 2014 5:11:10 AM(UTC)
richardgatarski
Don't know. But why not just split the HDMI cable from the camera. HDMI splitters are cheap and in abundance...
Ph0en1x
#3 Posted : Friday, October 3, 2014 5:45:12 PM(UTC)
Ph0en1x
Well my train of thought was that I then would need yet another HDMI capture device for the Windows PC, which would cut into my available budget, but I guess it slipped my mind that component video requires a capture device all the same. :/
I just can't get my head around the fact that you need to spend hundreds of dollars to get a halfway decent live videostream from one very basic camera to two separate devices, but maybe it's just me.
