-Updated-Video-Flash Lowerthird In-Loop-Out **Succesful**
Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Usually I used photoshop,after effect,premiere, but flash?? only 2 week ago and here it is the results. Lowerthird with --in - loop - out , and the posibility to edit the text. To control flash Lowerthird In - You need to click in your down left corner Lowerthird Out - you need to click in your right down corner. I will upload the swf , so that everyone check that is very functional Please comments. Josue Olvera
Joined: 3/7/2012(UTC) Posts: 2,682  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
Good work Josue! This has been a subject of ongoing discussion for some time now with vMix but it has not garnered a lot of support. The biggest issue is not having a functional controller to use Flash with vMix. Ambotz had done a lot of work and had developed a custom controller, but he has since fallen off the face of the map. It was the most promising development for dynamic motion graphics within vMix, but it seems to have died shortly after he stopped posting. I wish I was more adept at programing and coding, however, I just don't have a lot of time to learn a whole new "language" to duplicate what Ambotz had. You can check out some of the discussions here: http://forums.vmix.com.a....aspx?g=posts&t=1139http://forums.vmix.com.a....aspx?g=posts&t=1084Ice
joe1378 wrote:Usually I used photoshop,after effect,premiere, but flash?? only 2 week ago and here it is the results. Lowerthird with --in - loop - out , and the posibility to edit the text. Please comments. Josue Olvera If you can make the flash file I may be able to help with a control application for editing the text, or doing any control. I gave it a quick try a few months back, but didn't have the time to learn flash well enough to create a functioning animated title.
I forgot to mention, I did in my previous post.
To control flash
Josue Olvera
