Arnall
#1 Posted : Friday, September 26, 2014 12:20:51 PM(UTC)
Arnall
when you use multi view to create a scene with several overlays, you sometime want to resize/move the overlays and then resize/move the main (background) overlay. But the overlays are linked to the main and zoom/dezoom/move with the main background (the overlays are relative to the main), i would like to have an option for the background to be independant (acts as a normal layer).
Now i have to use a transparent background color as main layer but then i can only use 5 layers instead of 6!.
Thanks.
richardgatarski
#2 Posted : Friday, September 26, 2014 1:58:57 PM(UTC)
richardgatarski
Have you tried creating a virtual input of your "main" input, do the multiview on the virtual input and then resize/move the original "main" input?
(just an idea, have not tried myself)
