bloard
#1 Posted : Friday, September 26, 2014 10:27:52 AM(UTC)
bloard
I think this is due to basic misunderstanding of encoding formats, containers or a setting that mistakenly got changed on my end. Please help a dummy out as I've struggled with this for days.
I'm using a USB dongle to stream SD. I asked a couple of advertisers to send me commercials for me to insert. They came in a few different formats. When I load a big .mov file, it will play and stream fine. But the others are mp4s and when I try to play them I was getting an error in VMIX v13 when I would push the "Stream" button along the lines of "Audio capture device is not compatible with settings. FMLE Exited".
I uninstalled FMLE. Re-installed it (several times). Upgraded to VMIX v14 beta etc. I also did my last broadcast using FMLE - so it is working fine. Now my error in VMix v14 is simply "Streaing has stoppd unexpectedly FMLE Exited". Again, a .mov will stream, most other formats wont.
I downloaded Handbrake and tried to convert these files to other audio or video formats (tried a bunch of different settings) and I get the same errors.
So I guess my most basic question is... what is the preferred program similar to Handbrake to convert files of different types... and what are the preferred output settings to get a file that will for sure stream in VMix without any issues.
If you need any additional info to help, please don't hesitate to ask. Thanks
#2 Posted : Friday, September 26, 2014 11:16:21 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
The streaming error is unrelated to the video formats being played.
It is likely due to a problematic audio setting in vMix. Go to Settings -> Audio and make sure bit rate is 16 bit not 32 bit and restart.
bloard
#3 Posted : Friday, September 26, 2014 12:46:16 PM(UTC)
bloard
I also think part of the problem is that I messed with some audio settings somewhere. Here are my settings.
Master Sample Rate: 4410
Master Bit Rate: 16 bit PCM
Recording Audio: VMix Audio
Format: 44100 Hz, 16 bit 2 channels
