I'm trying to build a custom XAML that will show data coming from a SQL database. So far I've been successful in building a 'Hello World' XAML but I'm looking for more information on how to react to the interface. Or to put it different what should I implement in Load(), Play(), Close() and what's the idea behind the position as a TimeSpan.
All help is appreciated...
Willy
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
wleuvering wrote:Hi,
Willy I'm kind of confused about what you're trying to achieve here. If it's the .xaml file you're talking about, the only way of interacting with it is setting text-values that can be bound to other properties. Also, there are no "Play()" etc. that is used within the .xaml files, only two animation "Storyboards" that is being played back when used in vMix. Hope this was understandable, and if not, I'd recommend opening the already existing .xaml files that lies within the vMix installation directory with your favorite text editor to see how they are set up. Cheers, Håvard Njastad Webshop
No, it is wat is called a Custom XAML in the documentation. It is in Developers Information...
This is way to create a WPF Custom Control and program in C# which functions as a input. This should work just fine. Unfortunately I can not find a lot of documentation about it.
Joined: 1/13/2010(UTC) Posts: 5,331  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
The functions in the vMixWPFUserControl interface are all optional and it is fine to return 0 for the TimeSpan if you don't need to do anything.
These functions are called by vMix and should be self explanatory.
Load is called when vMix loads your custom control as an Input. Width and Height are the resolution vMix is using so you can layout your control correctly.
Play/Pause are when the button is clicked in vMix.
SetPosition is called when dragging the position bar in vMix. (As long as you have specified a duration in GetDuration > 0)
Close is called just before the input is closed in vMix.
Martin vMix
Martin, does this mean that it is possible to READ from a SQL database via the PLAY method and fill in fields in the layout ?
/Ulrik
In the load function you could setup your own threads and do whatever you need.
Hi, I'm fascinated of the possibility to design custom XAMLs on your own as overlays, etc. So I searched a lot and came up with the following XAML + CodeBehind (like jwolthuis mentioned in this topic), but it looks like the CodeBehind is completely ignored. Is this usage of a CodeBehind-File the right way? And is Usage of Bindings supported? Thanks a lot for answers! Code:<UserControl
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
mc:Ignorable="d"
x:Class="vMixTextTest.MainControl"
x:Name="UserControl"
d:DesignWidth="640" d:DesignHeight="480" Width="768" Height="576">
<Grid x:Name="LayoutRoot">
<TextBlock Name="txtText"
Text="{Binding Path=TextBehind, Mode=OneWay}"
HorizontalAlignment="Center" VerticalAlignment="Top"
Height="105.04" Width="264.007" Margin="37.993,25.96,0,0"
FontSize="26.667" FontWeight="ExtraBold"
Foreground="#FFC65555"/>
</Grid>
</UserControl>
Code:using System;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Threading;
using System.ComponentModel;
using vMixInterop;
namespace vMixTextTest
public partial class MainControl: UserControl, vMixWPFUserControl, INotifyPropertyChanged
private DispatcherTimer timer;
public MainControl() : base()
this.InitializeComponent();
LayoutRoot.DataContext = this;
timer = new DispatcherTimer();
timer.Interval = TimeSpan.FromSeconds(1);
timer.Tick += timer_Tick;
void timer_Tick(object sender, EventArgs e)
TextBehind = "Text " + DateTime.Now.ToLongTimeString();
public event PropertyChangedEventHandler PropertyChanged;
public void OnPropertyChanged(string propertyName)
if (PropertyChanged != null)
PropertyChanged(this, new PropertyChangedEventArgs(propertyName));
private string _textBehind = "testInit";
public string TextBehind{
get
return _textBehind;
private set
_textBehind = value;
OnPropertyChanged("TextBehind");
public static readonly DependencyProperty TextBehindProperty =
DependencyProperty.Register(
"Label",
typeof(string),
typeof(MainControl), new PropertyMetadata(""));
public void Load(int width, int height){ TextBehind = "testLoad"; }
public void Play(){ timer.Start(); }
public void Pause(){ timer.Stop(); }
public void SetPosition(TimeSpan position){}
public TimeSpan GetPosition(){ return new System.TimeSpan(0); }
public TimeSpan GetDuration(){ return new System.TimeSpan(0); }
public void Close(){}
public void ShowProperties(){}
 1 user thanked Marra for this useful post.
You will need to compile it into a DLL and then load that into vMix.
Just saw the option to open a DLL, Thank you Martin!!!
Works perfect
Thanks: 5 times Was thanked: 2 time(s) in 1 post(s)
