DDOtoo
#1 Posted : Tuesday, September 23, 2014 3:50:16 PM(UTC)
DDOtoo
Hello Martin,
I have noticed that in Vmix 13 I am not able to use the list input to play multiple music files. It stops after each file plays. That wasn't the case in Vmix 12. I usually use the list for about 15 mins before I do live broadcast to play some music over gospel slide shows. Now I have to loop same music or use the playlist feature which would mean opening up numerous audio inputs. I would appreciate it if you could look into it for me.
Thank you.
#2 Posted : Tuesday, September 23, 2014 8:52:01 PM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
Right click the List input and go to Edit and make sure Automatically play next item is ticked.
I have just tested the latest 13 release as well as the new 14 preview and both play the next music file in the list automatically.
http://forums.vmix.com.a....aspx?g=posts&t=2656
DDOtoo
#3 Posted : Tuesday, September 30, 2014 3:12:23 PM(UTC)
DDOtoo
Hello Martin, Yes it is ticked already yet it doesn't play automatically. I have unticked and ticked again, closed and re-opened and yet still won't play.
DD
#4 Posted : Tuesday, September 30, 2014 11:14:30 PM(UTC)
Please try the latest vMix 14 on our web site.
Not sure what the issue is as both versions work fine in my testing, but maybe it will work better for you.
