Joined: 10/10/2019(UTC) Posts: 65   Location: Düsseldorf Thanks: 5 times Was thanked: 17 time(s) in 10 post(s)
Hi, I just downloaded the OMT Viewer from Github. Is that normal that I don't have sound? Or is it just a Pre-release. Will Sound be implemented? The video is working great. Best regards. Michel
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
That is correct, it is a video only app at this stage. If you need more functionality including audio, a free option to consider is OBS with the free OMT plugin.
Joined: 5/16/2022(UTC) Posts: 8  Location: Oxford Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: admin  That is correct, it is a video only app at this stage. If you need more functionality including audio, a free option to consider is OBS with the free OMT plugin. A year-on has this not be resolved? What is the point of a mute video-only viewer? I have it running in OBS, but OBS runs CPU and GPU intensively and causes fan noise, plus the image is not as smooth at the OMT Viewer. Has development of the OMT Viewer just ground to a halt?
Joined: 3/18/2021(UTC) Posts: 46   Location: Tokyo Thanks: 19 times Was thanked: 14 time(s) in 11 post(s)
Originally Posted by: Oxford Blue  Originally Posted by: admin  That is correct, it is a video only app at this stage. If you need more functionality including audio, a free option to consider is OBS with the free OMT plugin. A year-on has this not be resolved? What is the point of a mute video-only viewer? I have it running in OBS, but OBS runs CPU and GPU intensively and causes fan noise, plus the image is not as smooth at the OMT Viewer. Has development of the OMT Viewer just ground to a halt? Hey. Please consider using community-made OMT tools as an alternative: https://github.com/Mikan...tory/omt-community-tools
