2 Pages<12
jet
#21 Posted : Tuesday, November 3, 2026 5:36:33 AM(UTC)
jet
Was thanked: 40 time(s) in 38 post(s)
Originally Posted by: xcapetir Go to Quoted Post
Hi Jani,
I checked the camera configuration and nothing in OMTake disables the iOS distortion correction. To narrow it down, could you tell me roughly how far the subject was from the iPhone during your test, and whether white balance was set to Manual? At short distances, iOS sometimes keeps the ultra-wide lens active even above 1.0x, and perspective at close range can also look like barrel distortion. If it turns out to be the lens switching, I can add an option to lock the main lens.
Kind regards,
Xavier
Hi Xavier!
The distance was about 20-30 meters.
Could't move the phone any nearer (the phone would otherwise be seen on other angles).
If I recall correcly WB was set to Locked.
Kind regards,
Jani
jet
#22 Posted : Tuesday, November 17, 2026 8:44:04 PM(UTC)
jet
Hi Xavier!
Asked these before, here they are again:
Would be very handy if the Exposure and other sliders on the Camera Settings panel would be on the top of the panel (now on the bottom in V1.6) This would make adjusting video image more convenient when you don't need to expand the full panel to get access to these. Exposure compensation should be on the top, then Hue, Temperature and the rest of the items.
Is it possible to make OMTake to run in the background so that when switching for example to iOS Settings OMTake would still be able to stream?
Kind regards,
Jani
jet
#23 Posted : Tuesday, November 17, 2026 8:45:12 PM(UTC)
jet
Feature request:
Turn off/on Tally Light (torch) -feature.
Kind regards,
Jani
jet
#24 Posted : Tuesday, November 24, 2026 11:34:31 PM(UTC)
jet
Feature request:
Quality setting: "Default".
This would give the Receiver the power to change the quality setting between Low-Medium-High, so for example if available network bandwidth is getting low the vMix operator could fix the issue just by changing the bitrate to a lower one from vMix.
Kind regards,
Jani
2 Pages<12
