GTiDon
#1 Posted : Monday, November 16, 2026 4:03:09 PM(UTC)
GTiDon
Hi All
Youtube Live stopped natively supporting PAL frame rates around 2020.
Instead now it duplicates frames to upscale 25p to 30p and 50p to 60p.
I do sports broadcasting, specifically motor racing and the duplicate frames cause terrible looking judder. Most of our cameras and gear are PAL locked and cannot be switched to NTSC,
The only solution I can see at the moment is to run some kind of real-time frame interpolation (optical flow) to generate the missing frames.. Has any solutions been tested.
This is also a Feature request to implement the option to add syntax into the stream FFMPEG encoders.
I think this is a very serious critical issue to be looked at effecting any PAL VMIX user that streams to Youtube
thanks 1 user thanked GTiDon for this useful post.
jet on 11/16/2026(UTC)
jet
#2 Posted : Monday, November 16, 2026 8:44:51 PM(UTC)
jet
Was thanked: 40 time(s) in 38 post(s)
Originally Posted by: GTiDon Go to Quoted Post
Hi All
Yes, noticed this also years ago.
Very stupid decision from YouTube not to respect the original frame rate on Live streams! Everything worked great before this..
However it still respects the original frame rate if video is uploaded as a file.
