Feature Requests
API access to the main MultiView output
Hi all,
Really enjoying the vMix 30 preview so far. I noticed the XML now has an <outputs> section that shows which output is running the MultiView, which is handy.
Would it be possible to go one step further and expose the MultiView itself in the API? Even just the current layout and which input is in each box would already help a lot. Being able to change a box’s input with a shortcut function would be Beautiful.
We run our live productions mostly automated with Companion, plus a small monitoring screen for the operators. The MultiView is the one thing we still can’t read or adjust from outside vMix.
Just to be clear, I mean the main MultiView output, not an input’s MultiView layers (those can already be set with SetMultiViewOverlay). Thanks for all the great work!
Daniele
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Yes please! Changing the inputs in the multiviewer boxes with just Companion and not going into settings would be SO great, and ideally use the input names not numbers
Feature Requests
