Instant Replay
Instant Replay Preview Window Size – Can It Be Increased?
Joined: 12/10/2020(UTC) Posts: 11  Location: Diyarbakır Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
 Hello everyone, I am using the Instant Replay feature in vMix and I would like to ask about the preview window sizes. In the Instant Replay Controller, the preview monitors (camera previews at the top of the window) appear quite small. I can enlarge the whole Instant Replay window, but I cannot find a way to individually increase or scale the size of the preview monitors themselves. My questions are: Is it possible to manually resize or zoom the preview windows in the Instant Replay Controller? Or are the preview sizes fixed and only scaled automatically based on the window size and number of replay cameras? If there is any recommended workflow or setting to make these previews larger and easier to monitor during live production, I would really appreciate your advice. Thank you in advance. Best regards, Veysel
Joined: 12/3/2013(UTC) Posts: 123   Location: Arizona Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
Did you ever figure this out?
Joined: 7/1/2020(UTC) Posts: 106  Location: Earth Was thanked: 23 time(s) in 20 post(s)
you can drag the thin grey line above the LIVE button to resize the monitor area, although looks like it's already maxed. another option is to add Replay A and B to the layers of a input and create a 2UP of the output channels. this will make them about as big as you can get. assign the input to a fullscreen output to feed a monitor, or assign to an output and utilize NDI to get it in a window you can put anywhere on your desktop.
Instant Replay
