Hello.
Will the KATOVISION KT-UH86DHN camera work well with the vMix software and the SMC75-vMix control console? Will I be able to utilize the full PTZ capabilities of these cameras? And will the recording quality—especially in low-light conditions—be good?
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Normally, there shouldn't be any issues. To be sure, check with vMix support. The KATOVISION KT-UH86DHN uses a 1/2.5-inch CMOS sensor, so it’s not great in low light, though it might be satisfactory. It all depends on your requirements. A camera with a 1-inch sensor would be much better.
