SRT
How to show "no signal" color bar if incoming SRT connection gets cut off
Hello all.
One simple question, is it possible to have vmix show a color bar (as no signal) when an incoming srt connection gets disconnected. Now I have a problem that if a sudden disconnect happens, the SRT input is stuck on the last frame received. I thought of adding a colorbar input and listen for a change in the state of the SRT input via API but I dont see any event or state that can trigger the Cut to color bar.
Has anyone managed to solve this?
Joined: 3/21/2022(UTC) Posts: 52  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Thanks Good idea, maybe a feature request for vMix would be a trigger to fire on a input on "signal loss".
One workaround while there's no API event: a script that polls the vMix API (/api) and watches the SRT input's state or its audio meters. If they go flat for N seconds, it triggers a cut to your bars or slate input. It's crude, but it works without a feature request.
Curious what the SRT feed is from. Remote contribution from a venue? I'm researching how people handle remote feed drops (I work on SRT/RTMP ingest), and I'd love to hear more if you're open to a short chat.
Liam
SRT
