Systems
Assistance with a vMix Workstation Configuration
Could you please provide a technical assessment of the following configuration?
Option 1: AMD platform
AMD Ryzen 9 9900X MSI MEG X870E ACE MAX — if I understand correctly, it offers three PCIe slots with direct CPU connectivity RTX 5060 Ti 16 GB — installed in PCIe slot 1, operating at x8. DeckLink 8K Pro Mini — installed in PCIe slot 2, operating at x8. DeckLink Duo 2 — installed in PCIe slot 3, operating at x4 (with the M2.1 slot disabled in the BIOS). NVMe SSD: 2 TB — installed in the M2.2 slot, operating at x4 with a direct CPU connection. RAM: 32 GB.
Would this configuration be suitable for either of the following scenarios?
Scenario 1: 6 HD 1080p cameras at 25 fps. 2 external 4K sources at 25 fps. Camera ISO recording. Program recording. 1 live stream 1080p25 and a few additional sources. No instant replay.
Scenario 2: 4x 4K cameras at 25 fps. 2x external 1080p sources at 25 fps. ISO recording directly on the cameras. 4K25p program recording. 1 live stream at 1080p25 A few additional sources. No instant replay.
Option 2: Intel platform
Initially, I was considering the following configuration: Intel Core Ultra 5 250KF ASUS ProArt Z890-Creator WiFi or MSI MPG Z890 Carbon WiFi. RTX 5060 Ti 16 GB — installed in PCIe slot 1, operating at x8. DeckLink 8K Pro Mini — installed in PCIe slot 2, operating at x8. DeckLink Duo 2 — installed in PCIe slot 3, operating at x4, connected through the chipset rather than directly to the CPU. Would this be safe? NVMe SSD: 2 TB — installed in the M2.1 slot, operating at x4 with a direct CPU connection. RAM 32 Go
Would connecting the DeckLink Duo 2 through the chipset be a deal-breaker? Would it inevitably cause lag, dropped frames, or other performance issues?
Would this Intel configuration be powerful enough to handle both scenarios described above?
Intel ou AMD : VMix fonctionne t'il mieux sur une des 2 platformes ?
Thank you very much for your valuable help and advice.
Systems
