Hardware Compatibility
Green vertical line in BMD Decklink hdmi mini monitor out
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Any body else have the same problem? Green vertical line (about one pixel width) in left side of the picture, from top to bottom. Very narrow but very visible on big tv monitor. Has it it something to do with vmix or is the decklink card defective? https://www.dropbox.com/...8b/green%20line.png?dl=0Vmix 12, 4K, matrox vs4, decklink minimonitor,
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
I had the same during livestreams result on YT but not on my monitor
Joined: 9/18/2014(UTC) Posts: 11 Location: Kazakhstan
doggy wrote:I had the same during livestreams result on YT but not on my monitor
I noticed the same when the program output size is different than input size of your source. For example i had SD input source 720x576. Program output size was 854x480. This difference made a green line on the right of the stream output in FMLE.
We have same input and output format, matrox vs4 sdi in cameras 720 50p and decklink mini monitor out 720 50p.
