Hardware Compatibility
Dropped Frames after upgrading to Windows 11
Experiencing dropped source frames which cause loss of signal from camera and computer inputs for a split second intermittently. Started happening after upgrading to Windows 11 with all the latest updates. RTX 2060, Cam Link Pro internal 4 port capture card, latest vmix version 29. All worked fine on Windows 10. Tried adjusting every vmix setting and windows power setting I could find. Anyone else experience similar issue?  Frames.jpg (141kb) downloaded 40 time(s). Diagnostics.jpg (158kb) downloaded 40 time(s).
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Hi, windows 11 26h2 ? try install Windows 11 25h2
Posting a followup note should anyone else run into the same problem.
Windows 11 seems to handle the motherboard/chipset drivers differently than Windows 10 but after trying everything, I stuck the Camlink capture card in another computer with Windows 11 and it worked properly. It turns out the PCIe x4 slot was controlled/communicating with the chipset. In the second computer I put the card in a x8 slot controlled/communicating directly with the cpu and there were no dropped source frames at all. It mattered more on my configuration as I have 2 hdmi sources into the card instead of just 1. Vmix guys did a video on PCIe and Lanes which lead me to try this solution.
